Do you have any questions?
SOLO 20
Building instruction
Exploded drawing
Assembly
The cabinet sections are cut in accordance with the parts list and glued together. Next, the openings and recesses for the loudspeaker and terminal connections can be cut out.
Inner damping
The damping material is evenly distributed in the cabinet.
Cabinet parts list for 1 box
Parts
Size (mm)
Quantity
Material: 19 mm MDF or chipboard
Front / rear panel
315 x 315
2
Top / bottom panel
315 x 277
2
Side panels
277 x 277
2
Crossover
Contact us
