Do you have any questions?
VIB 2000 GF
Art. No. 5906
*Bei den Preisen handelt es sich um Bruttopreise für Privatkunden.
Building instruction
Exploded drawing
Assembly
The circular cut-out (73 mm ø) in the baffle is for the BR 15.34 tube. The 78 mm cut-out in the rear panel is for mounting the ST 77 terminals. The crossover unit is mounted on the panel behind the bass cut-out.
Inner damping
The damping is a simple matter: as shown in the diagram, the four free square openings of the stiffening construction take one mat each, so that the upper part of the speaker cabinet is loosely filled. The lower part is left completely empty.
Zuschnittliste für 1 Box
Parts
Size (mm)
Quantity
Material: 19 mm chipboard or MDF
Front / rear panel
210 x 862
2
Side panels
900 x 296
2
Top / bottom panel
210 x 296
2
Brace
210 x 100
2
Brace
258 x 100
2
Base panel
258 x 210
1
Inner Damping
Crossover
Contact us
