Do you have any questions?
CENTER 130
For Dolby(r)surround and multimedia systems, where larger speakers are a requirement, the ideal choice is the CENTER 130 model. At the higher end of the range, the new magnetically screened 25 mm SC 10 N 8 Ohmtextile dome units are used. At the higher end of the range, the new magnetically screened 25 mm SC 10 N 8 Ohm textile dome units are used. The SC 13 8 Ohm 's are arranged symmetrically around the tweeter and are separated using two low-pass filters with differing characteristics in order to avoid wave cancellation affects around the tweeter. In this way, the sound source is always positioned around the centre and will match the on-screen visual action.
Thanks to the excellent power handling capabilities and the linear frequency response of the CENTER 130, home video presentations become a cinematic event. In multimedia applications, two CENTER 130's are used to reproduce the computer sounds, which really bring out the best in your soundcard.
Press
Extract from Audio Vision
"The surprise candidate during the test series came from Visaton. The CENTER 130 produced a well-rounded sound, whose crisp mid-range was particularly worthy of note"... Without including your own work and the costs of materials, the value for money is exceptionally good."
Technical Data
Component parts list
Additional Content
Rated power 100 W
Maximum power 150 W
Nominal impedance Z 4 Ohm
Übertragungsbereich (-10 dB) 50 - 22000 Hz
Mittlerer Schalldruckpegel 88 dB (1 W/1 m)
Trennfrequenz 3500 Hz
Gehäuseprinzip closed
Net volume 11.5 l
Außenmaß Höhe 160 mm
Außenmaß Breite 413 mm
Außenmaß Tiefe 250 mm
Component parts list for 1 box
Tweeter
SC 10 N 8 Ohm
1 pc.
Bass-midrange driver:
SC 13 8 Ohm
2 pcs.
Crossover
Crossover Center 130
Terminal
ST 77
1 pc.
Damping material
1/2 bag
Protective grille
Center 130
1 pc.
Wood screws
3.5 x 19 mm
8 pcs.
4 x 20 mm
8 pcs.
Cable
2 x 1,5 mm2
1,5 m
Frequency- and impedance response
Contact us
